1. AC Question's Avatar
    Hello
    I've got the samsung s6 running mashmellow 6.01.
    I'm trying to create a slideshow of my photos in gallery but it insists on going though the pictures newest to oldest, any ideas how to change this?
    Thanks
    06-21-2016 03:34 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! What app are you using to create the slideshow? Do you want to set the order yourself, or make it random?
    06-21-2016 04:15 PM
  3. Will2k's Avatar
    I'm using in the built in app 'gallery' and I'm wanting to set the order my self.
    06-22-2016 05:00 AM
  4. B. Diddy's Avatar
    Stock gallery apps usually go in alphanumeric order of the filename. You'd probably have to rename each photo to get the order you want.
    06-22-2016 12:04 PM
  5. Will2k's Avatar
    Ok thanks,no simple solution then
    06-22-2016 04:51 PM
  1. Replies: 11
    Last Post: 06-24-2016, 10:05 AM
  2. How do I forward messages from ZTE Android?
    Last Post: 06-21-2016, 04:33 PM
  3. How do you make emojs larger?
    Last Post: 06-21-2016, 04:30 PM
  4. Why can't I install funo wear on my Samsung note 4?
    Last Post: 06-21-2016, 04:19 PM
  5. All auto reply apps do not work on my s5
    By Erickf18 in forum Android Apps
    Last Post: 06-21-2016, 03:09 PM
