1. AC Question's Avatar
    I have a galaxy s6. I've been using themes for awhile. I understand how to download and delete them. However, I had a theme applied and then there was a software update to my phone. After update part of the theme was removed from my phone. However, when I go to themes it still shows that theme as being "applied". I have applied the default theme and it stays at 0% for awhile and then it goes to 100% the says "the theme store application has stopped working." But the default theme was mostly installed. But when I go to the theme store it still shows the other theme as being applied. I have cleared the cache of the theme store, Galaxy apse, system file theme and then cleared data also. I restarted my phone on several occasions but nothing seems to work.
    06-23-2016 12:48 AM
  1. S6 Edge home button not working after Wet Apply screen protector
    By JD72883 in forum Samsung Galaxy S6 edge
    Last Post: 06-24-2016, 06:49 AM
  2. Lenovo Yoga 8 stuck on erase screen after hard reboot
    By BINIL S in forum Lenovo Android Tablet Discussion
    Last Post: 06-23-2016, 11:29 AM
  3. What is wrong with my phone?
    By Facioquodvolo in forum Samsung Galaxy S6
    Last Post: 06-23-2016, 10:13 AM
  4. Replies: 1
    Last Post: 06-23-2016, 12:05 AM
