1. AC Question's Avatar
    I have a Droid Turbo 2 with Android 6.0. and here are the symptoms:
    - Running hot to the touch most of the time
    - Fast draining battery considering the amount of usage compared to my typical usage
    It started a couple of days ago when I was in a different area. I charged my phone at the airport and that's when I noticed it was draining fast and running hot. I have used standby mode two times today and that seems to fix the issue (i.e. the battery lasts longer and it doesn't run hot). Things I have done are:
    - Cleared the cache partition
    - Edited wifi to not stay on during sleep
    - Updated my network to LTE from global
    I feel like it may be a network issue where its continually searching for a network even tho I have a good connection OR it could be a problem with Google Services because its the top battery consumer? Thoughts?
    06-25-2016 09:18 PM
  2. hitokiri's Avatar
    Same here. Google services is doing it. When looking into it further, it seems my Gmail accounts get stuck in an endless sync loop and it burns through the battery.
    I have had 3 different droid turbo 2's do this. It must be a marshmallow bug.
    My only work around is using gsam to alert me when the battery is becoming hot, then use an auto sync toggle widget to kill the syncs. Turn it back on 15 min later and it's "fixed"
    07-21-2016 09:14 AM
  1. APN and group message problem
    By Scumperjumper in forum LG G4
    Last Post: 06-26-2016, 01:35 AM
  2. My lenovo tab app is fast make my game unbeatable
    By Rendell Sibal in forum Android Apps
    Last Post: 06-26-2016, 01:26 AM
  3. Replies: 1
    Last Post: 06-25-2016, 10:17 PM
  4. Last Word on Screen and Audio Quality
    By hpilot in forum OnePlus 3 & 3T
    Last Post: 06-25-2016, 07:58 PM
  5. Moto G 2015 Battery LED Stuck On?
    Last Post: 06-25-2016, 06:22 PM
