1. AC Question's Avatar
    For the past couple weeks the screen on my phone has been slowly separating from the body. As of now, on three of its four sides it's lifted about 1/16 of an inch. So with that I can look into the actual phone from under the LCD. I'm not sure if I should just use it until it's completely separated and I'm unable to use it anymore or if I can make an easy fix and make it last. Thanks
    07-03-2016 02:53 PM
  2. hallux's Avatar
    Sounds like the battery may be bloating. If the screen can't be easily pressed back I would suggest discontinuing use of the device ASAP. The battery could burst at any time and cause serious harm.
    belodion likes this.
    07-03-2016 03:37 PM
  3. belodion's Avatar
    I believe that in phones with screens held in place by adhesives, special adhesives are used, so proceed with care.
    Edit: Posted same moment as above post.
    07-03-2016 03:38 PM
  4. Carson Akers's Avatar
    This is the same person that asked the question. So I can push the screen in all the way in to where it should be and from the looks of it, it's looks pretty flat, even on the back side of the phone.
    07-03-2016 05:13 PM
  5. Carson Akers's Avatar
    Ok so with that I can see the actual adhesive across the boarder of the phone so do you think that I could buy an adhesive on Amazon and DIY it?
    07-03-2016 05:19 PM
  6. belodion's Avatar
    Welcome as a new member.
    hallux's point about a failing expanding battery pushing the screen up is a good one, which did not come to mind when I replied, but if you're certain that the battery is not doing that, then yes, a DIY repair may be possible. Try to find out first what type of adhesive was used for your particular phone.
    07-03-2016 06:13 PM
  7. Carson Akers's Avatar
    Alright cool. I'll stop at my local phone repair and ask them what type of adhesive I should use. Thanks!
    07-04-2016 11:15 AM
  1. Why can't I remove my google account from my LG G3?
    Last Post: 07-03-2016, 08:25 PM
  2. What is wrong with my S6 Edge screen????
    Last Post: 07-03-2016, 07:05 PM
  3. Why won't my touch screen respond to my touch?
    Last Post: 07-03-2016, 03:27 PM
  4. Replies: 1
    Last Post: 07-03-2016, 12:57 PM
  5. Replies: 1
    Last Post: 07-03-2016, 12:14 PM
