1. AC Question's Avatar
    Ok so get this. I went to bed with my phone on 73% and by the time i woke up the thing was DEAD! How could i drop 73% in idle?????? Like does anyone know anything about premature battery drain? I just couldnt believe this its beyond me. And the thing is it keeps dropping even when im not doing anything on it. Like what the heck is wrong with the battery? Is it the battery itself or apps just running the whole time. I really need some help with this because i cant even use this phone anymore without the battery draining so damn fast its really beyond me at this point in time.
    HELP
    07-03-2016 05:31 PM
  2. belodion's Avatar
    What did your battery usage stats indicate as the cause of the drain?
    07-03-2016 05:57 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    You might have to install a 3rd party battery monitor like GSam Battery Monitor to see your cell signal strength.
    07-03-2016 05:58 PM
  1. lg stylo 2 plus messaging not working
    Last Post: 07-03-2016, 06:43 PM
  2. Why My huawei mt7L10 motion control is empty
    Last Post: 07-03-2016, 06:21 PM
  3. Replies: 1
    Last Post: 07-03-2016, 06:09 PM
  4. Gear VR and the S7 edge
    By Retinella in forum Samsung Galaxy S7 edge
    Last Post: 07-03-2016, 05:07 PM
