1. WillyScott63's Avatar
    My wife's s6 has started to drain to 0% in just a few seconds. I can't imagine it being an app that is causing this to happen. It seems random for now. I know it has happened with two GPS apps. One is Runkeeper the other is the Weather channel. I would think that the phone would get real hot if the battery actually drained that fast.
    Attached Thumbnails Why is the s6 battery draining from 94% to 0% in a matter of seconds?-screen1.jpg   Why is the s6 battery draining from 94% to 0% in a matter of seconds?-screen2.jpg
    07-04-2016 03:35 PM
  2. the tall guy's Avatar
    Hi, it doesn't sound right - can you upload screen shots of the battery stats for us to look at?
    07-04-2016 04:29 PM
  3. ducbucln's Avatar
    If you google "google play services" and "battery drain" you will find all kinds of problems since the most recent update of google play services. I haven't found a solution yet. I've tried uninstalling google play services but it keeps reinstalling itself causing the battery drain again.
    07-04-2016 09:35 PM
  4. WillyScott63's Avatar
    It seems really odd to drop so fast. The second image was running in safe mode. I think my wife said it was around 42% when she started looking at facebook. Wile she was doing that it had the sharp drop to 0%.
    07-04-2016 09:45 PM
  5. tube517's Avatar
    First guess is something draining that fast is the battery needs to be replaced.
    EDIT: Nevermind,I see that it is an S6. Use GSam Battery app and see if any app is just misbehaving badly.
    07-04-2016 09:47 PM
  6. WillyScott63's Avatar
    I posted 2 of the battery usages. One was in regular mode with the huge drop of 90+% to 0% in one second. The other was in safe mode so only Samsung/Google apps.
    tube517 likes this.
    07-04-2016 09:55 PM
  7. tube517's Avatar
    Gsam is a better indicator of battery life than the stock battery graph and may be able to pinpoint the app
    07-06-2016 12:56 PM
  1. Replies: 2
    Last Post: 07-05-2016, 11:15 AM
  2. Run out of storage on my S4 Mini
    Last Post: 07-04-2016, 04:30 PM
  3. Replies: 0
    Last Post: 07-04-2016, 03:33 PM
  4. What happened to the Trace function?
    Last Post: 07-04-2016, 03:28 PM
  5. Why do pictures not show on linked contacts?
    Last Post: 07-04-2016, 03:12 PM
