1. AC Question's Avatar
    Hi guys,
    i recently replaced an LCD because of broken glass on my Lenovo S60. The process went great but after that i noticed i cannot connect to any WiFi. Phone finds all wifi networks with a good signal strength but there is an "WIFI AUTHENTIFICATION ERROR" with any wifi i try to connect. I tried hard reset and some other stuff but it didnt work.
    Do you think it can be software issue or i just ****ed up the wifi during replacement of LCD?
    Thank you very much for help, have a nice day
    07-05-2016 04:12 PM
  2. anon(632115)'s Avatar
    Hmm it is quite easy to accidentally disconnect the wifi/bt module. But you wouldn't see any wifi networks. Is your device displaying a mac address? Does Bluetooth Work?
    07-05-2016 04:18 PM
  3. filiphanak's Avatar
    hmm, thank you for a reply, i thought WiFi/BT module is part of the motherboard, isn't it? But MAC adress is showing up, and i BT can be turned on, i can try tomorrow its functionality.
    EDIT: MAC adress is showing up but IP adress is not showing up, i dont know if it is normal onr not :)
    Thank you
    07-05-2016 04:28 PM
  4. anon(632115)'s Avatar
    Hmmm. THis is strange. When at home can you make your Wi-Fi network "open" by removing the password and see if you can access it?
    07-06-2016 04:19 AM
  5. filiphanak's Avatar
    yes i tried make wifi open, it didnt help. Next step is to try flash new android ROM to see if it helps, i hope so
    07-06-2016 09:57 AM
  1. can you block text messages on an lg g4
    Last Post: 02-17-2017, 05:55 PM
  2. Transfer Wifi passwords to M10
    By HnLA in forum HTC One M8
    Last Post: 07-11-2016, 06:32 AM
  3. damaged sd card message everytime i turn on my phone
    Last Post: 07-05-2016, 04:27 PM
  4. My Galaxy s5 is frozen with a blue screen
    Last Post: 07-05-2016, 03:42 PM
  5. Why do callers hear an echo when calling me on my S7?
    Last Post: 07-05-2016, 03:32 PM
