1. AC Question's Avatar
    i edit my rooted phone by putting bigger battery but the percent level going crazy so i thought by editing an battery file from system would fix it but it ruin the phone
    i even instal flash rom but still same problem
    plus i try another two batteries still same
    07-08-2016 07:57 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. Did you make a change in the build.prop?
    07-08-2016 09:31 AM
  1. Replies: 8
    Last Post: 07-08-2016, 08:58 AM
  2. Replies: 0
    Last Post: 07-08-2016, 07:33 AM
  3. Lg realm keeps getting stick on logo or symbol screen
    Last Post: 07-08-2016, 06:52 AM
  4. Why the screen is suddenly turning into green..
    Last Post: 07-08-2016, 06:43 AM
