1. AC Question's Avatar
    When my screen is off and you double tap to turn the phone on it does not work
    07-08-2016 11:41 AM
  2. Javier P's Avatar
    Welcome to the forums. What device do you have? Is it an LG device? If so, go to settings - display - screen lock and make sure the settings for Knock Code are checked and correct.
    07-08-2016 12:29 PM
  1. How can I sync email without data plan on paired phone?
    By spw303 in forum LG Watch Urbane 2nd Edition
    Last Post: 07-11-2016, 10:07 AM
  2. Why is my google search app opening on it's own?!?!?!?!?
    By Nuclear Drake in forum Android Apps
    Last Post: 07-08-2016, 04:08 PM
  3. Replies: 3
    Last Post: 07-08-2016, 03:23 PM
  4. Replies: 2
    Last Post: 07-08-2016, 11:55 AM
  5. Can anyone get the PIT file for the s6 (Model is sm-s906l)\
    Last Post: 07-08-2016, 11:16 AM
