1. AC Question's Avatar
    I have an HTC 10 and for some reason the wifi and airplane mode stopped working together
    07-09-2016 05:26 AM
  2. chanchan05's Avatar
    You can only use wifi if you turn it on after going airplane mode.
    07-09-2016 06:02 AM
  3. Dngrsone's Avatar
    "Airplane Mode" is designed to turn off all the radios on your cell phone. That's what it does. The reason behind this is that (until recently) the FAA required all radio frequency emitting devices in the cabin be turned off during flight, and particularly during the critical phases of taking off and landing.
    These restrictions have been relaxed, to a certain extent, though many airlines still ask you to turn off or put into airplane mode your devices prior to takeoff or landing.
    Once you are in airplane mode, you can selectively turn on your WiFi and/or Bluetooth.
    07-09-2016 09:38 AM
  1. Replies: 1
    Last Post: 07-09-2016, 11:43 AM
  2. Can I delete account on an apk downloaded app?
    Last Post: 07-09-2016, 07:15 AM
  3. Grand Prime Stuck On "Android is starting... Starting up apps."
    By Deadpool Dude in forum Samsung Galaxy Grand
    Last Post: 07-09-2016, 06:20 AM
  4. No 'Add New Task' option on my S Planner - Galaxy 7
    By DomCooper in forum Samsung Galaxy S7
    Last Post: 07-09-2016, 05:52 AM
  5. Why wont my notification widget pull down
    Last Post: 07-09-2016, 04:07 AM
