1. AC Question's Avatar
    Recently purchased a samsung gear fit 2, and so far I have loved it. However, a couple days ago I ran it under the sink and dried it off after a run, and shortly afterwards, the floor/stair estimator was completely off. It said I had climbed a ridiculous 104 floors in under three hours. I contacted samsung and a factory reset did not fix it. Does anyone have the same issue or solutions? Currently mine is in rice just in case there is moisture that affected it (even though it should be water resistant)
    Thanks for any info
    07-11-2016 10:18 PM
  1. Replies: 0
    Last Post: 07-11-2016, 10:01 PM
  2. Replies: 0
    Last Post: 07-11-2016, 08:53 PM
  3. Random Issues With Internal Memory, Any Help?
    By AC Question in forum LG Lucid
    Last Post: 07-11-2016, 08:48 PM
  4. How can a Samsung Galaxy S7 Duos, SM-G935F?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-11-2016, 08:42 PM
  5. marshmallow, bluetooth low quality audio issue
    By gokitty199 in forum Samsung Galaxy S6
    Last Post: 07-11-2016, 08:25 PM
