1. AC Question's Avatar
    Hey everyone,
    I dropped my Note 3 in a pool a few days ago. Took it out right away and removed the battery and sim card. I did not have any access to rice at the time so I let it dry out outside. When I got home I put it in a bag of rice for 2 days.
    Now everything works perfectly on the phone except that I cannot hear audio on it from the speakers nor can I speak to others on the phone when I call them. The audio does work when i plug in headphones though.
    Any advice for me to fix this issue? Thanks
    07-12-2016 02:38 PM
  2. nahoku's Avatar
    It could be anything from just the speaker to the motherboard. Hard to tell when water's involved. Your best bet is to take it to a repair shop for analysis. Note that it might cost you more to fix it than buying a replacement Note 3, or some other phone.
    07-12-2016 08:59 PM
  1. zw2 and note 4?
    By steveinil in forum ASUS ZenWatch 2
    Last Post: 01-04-2017, 11:52 AM
  2. Is it possible to play Pokemon Go on Android 4.3
    Last Post: 07-28-2016, 05:03 AM
  3. Replies: 0
    Last Post: 07-12-2016, 02:29 PM
  4. Replies: 0
    Last Post: 07-12-2016, 02:14 PM
  5. Apps don't show in app drawer
    Last Post: 07-12-2016, 01:56 PM
