1. AC Question's Avatar
    It started two days ago when I noticed the percentage going down instead of up while on the charger some days it'll charge fine the next it's messing back up what's going on how can I fix this?
    07-13-2016 09:16 AM
  2. Javier P's Avatar
    Welcome to the forums. Have you already tried using a different wall charger and cable? If the problem persists maybe the battery is starting to fail. How old is your phone? Can you remove the battery and replace it for a new one?
    Golfdriver97 likes this.
    07-13-2016 09:38 AM
  3. Ryan7ful's Avatar
    I've noticed that this happens to me when I don't use the original charger for my LG V10 and don't have it plugged into the wall. Even if I use the same cord, if I plug it into a car port, computer, etc. rather than charging, it just slows the rate that the battery drains. Try using the original charger for your phone and plug it into the wall.
    07-13-2016 09:39 AM
  1. how can i update my LG l80 from 4.4.2 to 4.4.4
    Last Post: 09-08-2016, 10:18 AM
  2. Black dot at the corner of the screen
    By tkp206093 in forum Samsung Galaxy S7 Active
    Last Post: 07-18-2016, 04:10 PM
  3. Why are my emails failiing to sign?
    Last Post: 07-13-2016, 09:34 AM
  4. Replies: 1
    Last Post: 07-13-2016, 09:13 AM
  5. i don't want email on my android
    Last Post: 07-13-2016, 08:45 AM
