1. AC Question's Avatar
    I am using a digital signage app called viewneo on an android stick in version 4.2.2. I connect it to ethernet with a RJ45 ethernet to USB 2 adapter and set up a static IP address and gateway etc., making sure it's turned on and wi-fi is off. It will connect, I can start the app and be able to download content, but after a little while it gets disconnected without anything changing. The settings seem to be correct, I've tried different RJ45 adapters, and all the network ports are open and allowing access. If anyone has any ideas they would be greatly appreciated. Thanks!
    07-13-2016 03:04 PM
  1. Update Android 5.0 to 6.0.1 - lost "link" to Gallery in Message.
    By H-H Nygaard in forum Android 6.0 Marshmallow
    Last Post: 07-18-2016, 04:31 PM
  2. Replies: 3
    Last Post: 07-15-2016, 02:03 AM
  3. Replies: 1
    Last Post: 07-13-2016, 06:16 PM
  4. Screen Randomly Locks
    By mjw1964 in forum Samsung Galaxy Tab S2
    Last Post: 07-13-2016, 04:16 PM
  5. why am I getting @ sign-failed
    Last Post: 07-13-2016, 03:18 PM
