1. AC Question's Avatar
    I dropped my phone in water. The phone works but the screen doesn't light up. Is this repairable?
    (I know the phone works because I can blindly dial phone numbers and the phone makes noise.)
    07-16-2016 07:48 AM
  2. mehigh101's Avatar
    If you still have the warranty just go to the nearest sammy store and have it repaired. If not,don't try it to repair it yourself,you'll crack your screen or do something else. Go to a repair store and pay for it.
    Here are you can find the sammy stores near you -
    http://support-us.samsung.com/cyber/...sc_locator.jsp
    07-16-2016 08:00 AM
  3. Sherri64's Avatar
    Warranty covers water damage?
    07-16-2016 08:22 AM
  4. belodion's Avatar
    If the water was shallow, there might be impact damage as well as any water damage.
    07-16-2016 09:54 AM
  1. Lock screen doesn't shut off when charging
    Last Post: 07-16-2016, 08:39 AM
  2. Why does my lock screen have no security?
    Last Post: 07-16-2016, 07:49 AM
  3. My Samsung Galaxy J5 is stuck on Samsung logo
    Last Post: 07-16-2016, 07:47 AM
  4. Can I charge my galaxy s5 with 12 volt charger?
    Last Post: 07-16-2016, 06:33 AM
  5. Says i need to sign in to Google...and i am
    Last Post: 07-16-2016, 02:37 AM
