1. AC Question's Avatar
    my samsung s6 edge doesn't recognise when I tap or type. I can't get into it because it tells me i need to enter my password and I can't switch it off because I need to touch the screen to confirm. As far as I can tell there is nothing wrong with the screen and everything comes up as it should but just cant type. HELP!
    07-16-2016 12:56 PM
  2. belodion's Avatar
    Try holding Power and Volume Down for half a minute or so, as a simulated battery pull.
    07-16-2016 01:15 PM
  1. glalaxy s6 wont charge or open apps
    By idkwhatehappenedbutplshelp in forum Samsung Galaxy S6
    Last Post: 07-18-2016, 04:17 AM
  2. Replies: 2
    Last Post: 07-16-2016, 01:27 PM
  3. Replies: 1
    Last Post: 07-16-2016, 01:17 PM
  4. Replies: 1
    Last Post: 07-16-2016, 01:05 PM
  5. Replies: 1
    Last Post: 07-16-2016, 12:57 PM
