1. AC Question's Avatar
    so i have a moto x play (2015), today i was at the beach and i thought i left it in the car but after 10 minutes i saw it in the water next to me. I panicked and immediately started to dry it out. Once i got home i realized the screen was still working but the phone cant get past boot up. i even tried to use recovery to launch it. it didnt work and kept getting stuck at the android logo. I have it in a bag of rice right now and im letting in dry out for a couple days. Can someone tell me if the problem is still coming from water damage and/or if there are any other tips to get it to work??
    07-16-2016 11:43 PM
  2. Brandenwille19's Avatar
    I'm not professional but I would recommend (if you think your capable) to open the phone up and clean it with 99% alcohol because drying it only helps about 50%. When you dry it it only takes away the moisture but the water leaves minerals that cause the components to rust. But I would take it to a professional asap
    07-17-2016 12:32 AM
  1. GPS with Pokemon Go
    By mesocyclone30 in forum Samsung Galaxy S7
    Last Post: 08-24-2016, 01:39 PM
  2. Replies: 2
    Last Post: 07-23-2016, 08:46 PM
  3. Problem with my camera. Android Maxx
    By Dawn Sullivan1 in forum Ask a Question
    Last Post: 07-16-2016, 09:39 PM
  4. I need to close tabs
    Last Post: 07-16-2016, 09:08 PM
  5. Replies: 0
    Last Post: 07-16-2016, 08:53 PM
