1. AC Question's Avatar
    I have a phone charger that has an ouput of 5v-1a. So it means that when i charge the phone it should draw 1000 ma right? but my phone draw higher than that which is 1200-3000 ma, i saw that with an app i downloaded to check whether my charger is working properly. Do i need to worry? Is it going to damage my phone or do i need to replace my charger?.
    07-17-2016 06:01 AM
  2. Lodingi's Avatar
    Are you using the phone's original charger? If so, I wouldn't worry. How do you know the app you mention is giving an accurate reading?
    07-17-2016 06:11 AM
  3. pogiboris's Avatar
    yes i am using the original charger. And i dont know if the reading of the app i downloaded is accurate, but let us assume that it is accurate will it do any damage? does it mean that 1a output charger provide exact 1000ma?
    07-17-2016 06:53 AM
  4. mehigh101's Avatar
    1 ampere will charge a 1000mA battery in 1 hour. IF IT'S NOT BEING USED. Having your phone turned on consumes battery and your phone will get 1000mA - eg. 350mA= 650 mA/h. I think that's the simplest it can be
    07-17-2016 07:51 AM
  5. pogiboris's Avatar
    What if my phone receive more than 1a per hour? I am using a 1a charger and my phone receives over 1a per hour . Does thatvseem to be normal?
    07-17-2016 07:48 PM
  6. ctleng76's Avatar
    The amount of current that flows is determined by the device, not the charger. You could have a 2000 amp charger, but your device would only draw what it is designed to draw (probably between 1 or 2 amps). You never need to worry about a charger supplying too much current to your phone. As far as the phone drawing more current than the charger can handle, you don't need to worry either since the charger most likely has a current limiting design. I would be curious to know how that app determines current draw. I guess the phone report it to the app? The charger may also be able to supply more current than it is rated for.
    07-17-2016 08:29 PM
  7. pogiboris's Avatar
    Thank you for the response i think its just normal but i am just curious about it, i will not bother with it anymore.
    pkcable likes this.
    07-18-2016 08:20 AM
  1. MOD Question about the battery pack
    By beeare in forum Moto Z Force
    Last Post: 08-04-2016, 08:32 AM
  2. Replies: 1
    Last Post: 07-27-2016, 04:11 AM
  3. I'm hoping to upgrade my rooted android but..
    By SplendiferouslyStupid in forum Samsung Galaxy Tab 3 Rooting, ROMs, & Hacks
    Last Post: 07-19-2016, 06:57 AM
  4. I have a weird message on my locksreen
    Last Post: 07-17-2016, 11:47 PM
  5. should i buy the nexus 5x white or black? help pls i cant decide
    By Nastybloodlust in forum Ask a Question
    Last Post: 07-17-2016, 06:20 AM
