1. AC Question's Avatar
    I am having difficulty charging my phone. Using the wall charger requires luck and a lot of wiggling. Since that problem is with several different wall chargers I own I figured I would charge wirelessly. I have the Samsung puck. When I put phone on that the puck lights up blue like it is working but the phone does not show it is charging.
    Any ideas on what to do?
    07-17-2016 03:50 PM
  2. the tall guy's Avatar
    If wireless isn't working, then the problem sounds like it's coming from your phone. Are you sure the phone is sitting correctly on the wireless pad?
    07-27-2016 06:42 AM
  3. thisbearisdrunk's Avatar
    is the wireless charger compatible for the phone u have?
    07-27-2016 07:18 AM
  1. Replies: 6
    Last Post: 09-14-2016, 09:20 PM
  2. Replies: 1
    Last Post: 07-27-2016, 06:41 AM
  3. Should I swap my S7 with HTC 10?
    By Musadiq Khan1 in forum Samsung Galaxy S7
    Last Post: 07-18-2016, 01:23 PM
  4. My galaxy A6 shut off. Wont come back on.
    Last Post: 07-17-2016, 03:03 PM
  5. Unable to use wireless charging with otterbox defender
    By Bioking in forum Samsung Galaxy S7 Cases & Accessories
    Last Post: 07-17-2016, 02:27 PM
