1. AC Question's Avatar
    I have the galaxy S7. I used the actual phone today to talk to someone. Usually I talk thru a headset or thru the car speakers. I never had a volume issue. When in the call today, i thought the other person was on speaker phone. The call was very faint. i pushed the extra volume icon and it barely increased. The volume is all the way up on the phone. Is this a defect or is there a way to fix it? I've only had my phone for maybe 2 weeks.
    07-19-2016 05:52 PM
  2. Tim1954's Avatar
    Did it come up with that annoying message about high volumes may damage your hearing etc? Gives me the pips that does! Or you may have something in the speaker hole.....? Spill some sticky liquid on it? Mine is loud enough so you may have some issue there.. Good luck!
    07-20-2016 01:42 AM
  3. mehigh101's Avatar
    Welcome to Android Central!
    Test your phone's speaker volume/earphone's volume and see if it's a hardware problem.
    Best regards,Mikey. I hope you found what you were looking for.
    Sent from my Samsung Galaxy S7 Edge SM-G935F.
    07-20-2016 03:06 AM
  1. Replies: 1
    Last Post: 07-19-2016, 11:49 PM
  2. why am I getting message on google "can't open microphone"
    Last Post: 07-19-2016, 11:46 PM
  3. trying to reboot the Motorola phone
    Last Post: 07-19-2016, 05:49 PM
  4. Replies: 1
    Last Post: 07-19-2016, 05:45 PM
  5. Calls go directly to voicemail; won't ring
    Last Post: 07-19-2016, 05:19 PM
