07-22-2016 08:09 PM
35 12
tools Reply
  1. Rogue Wallflower's Avatar
    I'm working on that.... i already have a new phone from warrenty on the way. I just dont want them to try and pull a fast one on me and try to say oh the phone wasn't faulty. if it was the sd card then i wont put it in the new one.
    07-20-2016 11:52 AM
  2. Rogue Wallflower's Avatar
    Why does storage effect how the phone runs.... its storage
    07-20-2016 11:54 AM
  3. mehigh101's Avatar
    Try to run a phone without software and without a single bit of data in it and you shall see why.
    07-20-2016 12:26 PM
  4. Rogue Wallflower's Avatar
    wait no the card does say 10 on it i physically removed it now....
    07-20-2016 12:27 PM
  5. Rogue Wallflower's Avatar
    I meant the SD card, it's extra storage, it doesnt have my software or my data
    07-20-2016 12:36 PM
  6. Rogue Wallflower's Avatar
    It may have been the SD card, i dont know why or get how it would happen so suddenly, but im going to keep testing the theory, thank you for all the feedback. if that was the problem i'll just send the replacement phone back. i wish the tech guy from warranty suggested this.... he knew i had one since when he asked i said yes
    belodion likes this.
    07-20-2016 03:09 PM
  7. belodion's Avatar
    Good luck and tell us what the outcome is.
    Thanks to all who responded in this thread to my appeal for help.
    07-20-2016 03:27 PM
  8. Rogue Wallflower's Avatar
    it's back to normal, i charged it to full and have been repeating the just letting it sit, and its been a little over an hour and it just went down 1% which is way better then the 20+ % percent obviously. Now I just have to wait for the replacement phone to come in to send it back, too bad the people on the phone didn't think of the SD card. He did ask me if i had one but that was it.
    07-20-2016 05:56 PM
  9. D13H4RD2L1V3's Avatar
    So we found the culprit. A bad SD card.
    Planning to order a new SD card?
    07-20-2016 11:15 PM
  10. Rogue Wallflower's Avatar
    Yea, was the SD card for sure, i ran my tests fully, and round 2 without the SD card i got almost 2 days off of my battery (little to no use on full power) I know i wont get that if im playing games and what not XD but its better then 4 or 5 hours of no use and its dead.
    I may get a new SD card, all it had on it was my music/notification tones, so i could just put a few on my phone directly i dont listen to music really anymore on the phone was just using the songs as ring tones. The pictures i move to my dropbox anyway to take them off my phone so the sd card was a perk. If i do get one though I will not be buying it offline.
    belodion and D13H4RD2L1V3 like this.
    07-22-2016 08:09 PM
35 12
  1. Replies: 19
    Last Post: 11-15-2016, 01:02 PM
  2. July 19th CNet reports S7 Active failed 2 out of 4 water tests
    By PLaBar in forum Samsung Galaxy S7 Active
    Last Post: 08-03-2016, 11:08 AM
  3. Blue Coral Galaxy Note 7 looks fantastic in new leaked render!
    By Preach2k in forum Samsung Galaxy Note 7
    Last Post: 07-30-2016, 10:45 AM
  4. Replies: 3
    Last Post: 07-21-2016, 06:35 PM
