1. AC Question's Avatar
    I have had my Droid Turbo 2 since November 2015, the original charger became loose and I had to wiggle it and position it just right to get it to charge, then it just stopped, I can plug it into something else into it and it works fine. So I went to Verizon and bought a new charger, worked great for about a month, then did the same thing as the original charging cable, so I brought it back to Verizon, they just swapped one cable for the same exact same one, well that one started doing the same as the other 2. No matter what usb cable I plug into it, I have to wiggle it and position it just right to get it to work, then it can not be touched or it will stop charging. I think its the phone port, not the cable. Has anyone else had this problem?
    07-21-2016 01:34 PM
  2. mehigh101's Avatar
    Welcome to Android Central!
    You surely deformed the pins inside the port. That's why it's loose
    Best regards,Mikey. For any more questions,PM me. I hope you found what you were looking for.
    Sent from my Samsung Galaxy S7 Edge SM-G935F.
    07-21-2016 01:35 PM
  3. jevalladares's Avatar
    Hi all
    I have had this problem many times in the past. the most simple solution is not related to your phone; just buy a new USB cable.
    My daughter has had this issue with her tablet and her phone may times in the past, because she uses her phone/tablet when charging eventually damaging the cable. Just try changing the cable with a new one, make sure it's from a reliable maker and not a generic bad quality cable.
    Cheers.
    Erasmo
    07-21-2016 02:27 PM
  1. If the Note 7 Comes in Flat and Edge....
    By Aquila in forum Samsung Galaxy Note 7
    Last Post: 07-28-2016, 08:41 PM
  2. How to get Pokemon Go on the Ellipsis 8
    By AC Question in forum Pokemon Go
    Last Post: 07-21-2016, 10:26 PM
  3. Why wont my device let me move apps to SD card?
    By HonestScript in forum Ask a Question
    Last Post: 07-21-2016, 03:39 PM
  4. Windows 8 does not recognize my Samsung Avant phone
    Last Post: 07-21-2016, 12:45 PM
  5. My mic isn't working on the it 1101
    Last Post: 07-21-2016, 12:43 PM
