nexus 6 won't turn on or go into boot menu, solid green led when charging what can be done?
A
AC Question
about a week ago i put my nexus 6 to charge at about 15-20% when i got home and when iwent to pick it up it was off i tried turning on nothing happen, those not show the charging battery sign, tried going into boot menu by holding power + volume down and it did go a couple of times(no longer does this), i tried leaving charging for hours then trying again didn't work, tried charging through a mac laptop and then a windows laptop see if that could help it trickle some energy to turn on, took it to a shop they said the charging port was loose but because of the location of the mic they couldn't fix it,
i purchased a wireless charger from best buy and now instead of just black screen it shows a solid green led been charging about 8 hours and won't turn on or go into boot even tried holding power and volume down for 5min still shows no signs of live besides the led.
kemberley1
