1. AC Question's Avatar
    Hi,
    I made this post/thread because i couldn't find a solution to my problem through this forum and google.
    Here is my trouble:
    I was trying to install a twrp recovery and was following the instructions of a tutorial.
    -So first i installed flashify and proceeded to a back up of the current kernel and current recovery
    -Then downloaded a custom recovery image through TWRP release for my nexus 4
    -After this i accidentally flashed the recovery image to boot instead of recovery
    Now as you can guess the trouble is that my phone only boots to TWRP recovery instead of usual boot.
    I tried to find aswers on google and yet i didn't find a solution.
    I would be grateful for any help and wish to recover this mistake without using a factory reset if possible.
    Thank you, as you can see i am pretty new to this environment.
    07-24-2016 12:14 PM
  1. How to ROOT a Samsung S3?
    By AC Question in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 10-25-2016, 06:13 PM
  2. Replies: 1
    Last Post: 07-24-2016, 03:24 PM
  3. Why does internal storage drop SO much after a factory reset?
    By Stwutter in forum Android 6.0 Marshmallow
    Last Post: 07-24-2016, 11:54 AM
  4. Photo transfer from cell to laptop
    Last Post: 07-24-2016, 11:51 AM
  5. how to unlock bootloader in my huawei honor 4x?
    Last Post: 07-24-2016, 11:10 AM
