1. AC Question's Avatar
    I have Galaxy Note 2 GT-N7100 International Model running Android 4.4.2 KitKat N7100XXUFNL1 firmware. It was working fine until recently it crashed and upon reboot it stuck on Samsung Note II logo.
    While flashing stock firmware via Odin I get the following error. I also tried flashing latest TWRP but end up with the same error: NAND Write Start!! and fail
    Odin Says:
    <ID:0/003> Added!!
    <OSM> Enter CS for MD5..
    <OSM> Check MD5.. Do not unplug the cable..
    <OSM> Please wait..
    <OSM> N7100XXUFNL1_N7100ODDFNI1_N7100DDUFND1_HOME.tar.md 5 is valid.
    <OSM> Checking MD5 finished Sucessfully..
    <OSM> Leave CS..
    <ID:0/003> Odin v.3 engine (ID:3)..
    <ID:0/003> File analysis..
    <ID:0/003> SetupConnection..
    <ID:0/003> Initialzation..
    <ID:0/003> Get PIT for mapping..
    <ID:0/003> Firmware update start..
    <ID:0/003> sboot.bin
    <ID:0/003> NAND Write Start!!
    <ID:0/003>
    <ID:0/003> Complete(Write) operation failed.
    <OSM> All threads completed. (succeed 0 / failed 1)
    I hv tried different Odin versions including Odin 3.09, 3.11.1, 3.1.85, 3.4.0. Same error. Tried on Windows 10 an I don't have kies and tried all of my usb ports. Installed latest drivers + I hv never modified this device neither rooted or tinkered ever. Removed battery for each operation. I am afraid to use any PIT files as wrong PIT file may completely brick it.
    Moreover, booting into stock recovery gets the following errors:
    E:failed to mount /cache (Invalid argument)
    E:Can't mount /cache
    Installation aborted.
    E:failed to mount /cache (invalid argument
    E:Can't mount /cache/recovery/log
    E:Can't open /cache/recovery/log
    E;Can't mount /cache/recovery/last_log
    E:Can't open /cache/recovery/last_log
    E:Failed to mount /cache (Invalid argument)
    E:Can't mount /cache/recovery/last_install
    E:Can't open /cache/recovery/last_install
    However, I get recovery menus but cannot factory reset or wipe. I can't find a solution fo it. Any help will be appreciated.
    07-25-2016 06:09 AM
  2. the tall guy's Avatar
    Hi, just curious to see if you got the above sorted?
    08-01-2016 04:14 AM
  1. why is my phone charging after rebooting
    Last Post: 08-01-2016, 04:08 AM
  2. Help needed after update
    By tony5496 in forum Ask a Question
    Last Post: 08-01-2016, 04:06 AM
  3. Failing to sign in on e mail what can I do?
    Last Post: 08-01-2016, 03:58 AM
  4. I have a note 5
    Last Post: 07-25-2016, 07:40 AM
  5. Replies: 1
    Last Post: 07-25-2016, 05:50 AM
