1. AC Question's Avatar
    My phone is not charging when plugged in and i did just switch batteries so it not the batteries could it be the port how to fix it
    07-26-2016 04:03 AM
  2. belodion's Avatar
    It could be the port, but it could be something else.
    07-26-2016 05:51 AM
  3. tony bag o donuts's Avatar
    Which phone model do you have? Have you tried different cables? Different chargers? The port may be bad, but if your phone supports it, have you tried a wireless charger?
    Many variables are unknown at this point.
    A quick fix is just keep using an external battery charger and swapping out until the issue is narrowed down/ resolved.
    07-26-2016 06:29 AM
  1. Galaxy S5 - Marshmallow 6.0.1 - Unable to connect server
    Last Post: 07-28-2016, 02:14 AM
  2. Replies: 2
    Last Post: 07-26-2016, 11:00 AM
  3. Marshmallow- Latest security patch update causing battery to drain
    By Prashant Rungta in forum Ask a Question
    Last Post: 07-26-2016, 05:57 AM
  4. Replies: 1
    Last Post: 07-26-2016, 03:39 AM
  5. Why is my phone taking so long to unlock sim card and start?
    Last Post: 07-26-2016, 03:38 AM
