1. AC Question's Avatar
    Ok so my S6 edge plus will not charge. When I turn the phone completely off and charge overnight, it'll charge up to something random percent. (Yesterday morning it was 93% this morning 74%) but it won't charge at all when on or sleep. I took it to a store and they hooked it up and no charge. They told me to send it in, but I really want to make sure this isn't a soft ware glitch. Speaking of software glitches, I keep getting this pop up saying something about Gear VR (which I never had) and it says "download some samsung powersharing app. If you you don't, all the power will be transferred to other device" or something like that. And when I plug my charger in, the battery drains rapidly (it already drains when just sleep with nothing hooked up). I haven't dropped it or anything, so I don'the know what the issue is.
    07-26-2016 08:25 PM
  1. s7edge draining battery after june update
    By Edges7 in forum Samsung Galaxy S7 edge
    Last Post: 09-01-2016, 07:17 AM
  2. Turn off edge features
    By johnnyshinta in forum Samsung Galaxy S7 edge
    Last Post: 07-27-2016, 08:42 AM
  3. Bad battery life?
    By SilverMight in forum Motorola Droid MAXX
    Last Post: 07-26-2016, 09:21 PM
  4. Galaxy S6 Fell--Screen Black
    Last Post: 07-26-2016, 07:29 PM
  5. Given a Galaxy 3. I want to use a byop.
    Last Post: 07-26-2016, 06:24 PM
