1. AC Question's Avatar
    Hi guys, I have samsung note 3 . When the phone is ideal the battery dosent drains, but the moment i started using it, it starts draining, recently i changed my motherboard from samsung care,
    07-28-2016 01:22 AM
  2. Jo Kidlatan's Avatar
    Have you tried installing Battery saver apps in your and lowering your brightness?
    07-28-2016 03:07 AM
  3. AlphaTango414's Avatar
    Do NOT use battery saving apps. They are more harm then good!
    How long have you had this problem? Have you recently installed any apps around the time you started having high battery drain? Look and examine your battery usage screen to see what's been using the most battery.
    Has your service reception decreased recently? The worse the signal, the more battery drain you will have.
    You could first start out by wiping app cache via settings> storage. Then wiping system cache via recovery mode. Neither wipes any saved personal data.
    07-28-2016 04:27 AM
  4. nahoku's Avatar
    Along with what AlphaTango414 has posted, is the battery in your phone the original battery? How old is it?
    I also agree... Do NOT use battery saving apps!
    07-28-2016 05:13 AM
  1. i want to get rid of prompts when I write on my Samsing edge6
    Last Post: 08-01-2016, 07:11 AM
  2. i want to get rid of prompts when I write on my Samsing edge6
    Last Post: 08-01-2016, 07:04 AM
  3. How do I unlock the sim card on my old Android phone?
    Last Post: 07-28-2016, 02:20 AM
  4. Why Is My LG powered by Android phone charging backwards?
    Last Post: 07-28-2016, 02:19 AM
  5. i want to get rid of prompts when I write on my Samsing edge6
    Last Post: 07-28-2016, 01:08 AM
