1. AC Question's Avatar
    When I open up my camera it makes a sizzle noice...kind of like static on the radio noise. Is this BAD? Does anybody else's note 5 do this?
    07-28-2016 02:14 PM
  2. Bugslayer25's Avatar
    Yes, mine has done this for a while now. Also when I use the flash as a flashlight. One time it caused the camera image to flicker, bit usually it has no effect on the camera's function. I think it's something with the flash or image stabilizer.
    08-25-2016 11:57 AM
  1. Android Auto says "It is Offline"?
    By cclosterman in forum Android Auto
    Last Post: 09-18-2016, 07:02 PM
  2. Replies: 13
    Last Post: 08-17-2016, 09:52 PM
  3. Why can't I do a check deposit on Galaxy S4
    Last Post: 07-28-2016, 06:44 PM
  4. Replies: 2
    Last Post: 07-28-2016, 06:31 PM
  5. Replies: 1
    Last Post: 07-28-2016, 01:59 PM
