1. AC Question's Avatar
    My phone has been hacked by my scumbag neighbor should I be able to use internet off virgin verizon sprint boost apns? I know tmobile and will work. But what about the others? Carrier locked metro. Using verizon sprint cricket att tracfone boost virgin lycamobile apnvsettings. All work for internet????????
    07-28-2016 04:49 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Are you saying that you're suspicious of being hacked since the phone can suddenly access multiple carrier networks? Are you selecting these different networks in the Network Operators menu? If so, are you certain the phone is actually switching to that network?
    07-28-2016 06:07 PM
  3. Almeuit's Avatar
    You would have to use the network that your SIM card is tied to.
    07-28-2016 06:09 PM
  4. Roby Danielle's Avatar
    Its not just a suspicion he actually fried one phone already. And has boasted about what he is doing. I am able to run on att and metro in network operators. But am able to access 4g using multiple apns.
    07-29-2016 06:06 AM
  5. Roby Danielle's Avatar
    Also it seems when I am not locked to him as I assume he is using a cheap imsi catcher it won't run off these other apns just metro. I use signal trackers which show my tower being right over his lot.
    07-29-2016 10:32 AM
  6. anon(632115)'s Avatar
    Have you considered using a VPN?
    07-29-2016 10:36 AM
  7. B. Diddy's Avatar
    What this guy is doing seems to constitute illegal activity. Have you considered going to the authorities? Or at least small claims court. If he's boasted about it in messages to you, make sure you save them for future evidence.
    Aquila and belodion like this.
    07-29-2016 12:11 PM
  1. What is Rcp components and why is it on my phone?
    Last Post: 09-19-2016, 06:35 PM
  2. Replies: 3
    Last Post: 08-01-2016, 07:44 PM
  3. turn on system sound for Samsung Galaxy Tab 3 7.0
    Last Post: 07-29-2016, 12:09 PM
  4. Why is my VS9854GLTE cutting out during phone conversations?
    Last Post: 07-28-2016, 06:15 PM
  5. Replies: 2
    Last Post: 07-28-2016, 06:09 PM
