1. AC Question's Avatar
    This morning when I unplugged the charger, my S6 battery fell to 93% immediately (from 100%). The battery kept draining about 1% every minute. No apps were running. I did a reboot. The battery still kept draining.
    Does anyone know how to fix this? The last thing I did, was an overnight firmware update. I'm not sure the battery worked normally before that as I've mostly been playing Pokémon GO which drains the battery within 3 hours, but I think the battery life was still normal with the app closed. Thanks.
    PS I'm not doing the "turn off Wi-fi, GPS, and everything else you need to use the phone for anything other than calls and texts" nonsense which I have found lots of on google. I need the battery restored to previous performance under the same conditions.
    07-29-2016 12:54 AM
  2. nahoku's Avatar
    You might have to to troubleshoot. Good luck!
    07-29-2016 01:29 AM
  3. AlphaTango414's Avatar
    Wipe app cache via setting>system>storage.
    Wipe system cache via recovery mode.
    Neither wipes any personal data. Wiping these two are always recommended after any update.
    If you have taken a major OS update, you may need to do a factory data reset via recovery mode. This will wipe all user data.
    07-29-2016 03:06 AM
  4. baguette1's Avatar
    Sadly that didn't work. My phone got stuck in download mode and when I returned to normal mode, the battery was drained another 15%.
    07-29-2016 04:18 AM
  5. baguette1's Avatar
    It neither works, nor does this leave my phone functional. I can't use a phone without wi-fi or GPS.
    07-29-2016 04:20 AM
  1. Replies: 17
    Last Post: 08-01-2016, 01:17 PM
  2. 07/28/16 system update for LG G5 just bricked my phone
    Last Post: 07-29-2016, 12:42 AM
  3. Phone is hot and battery draining
    Last Post: 07-28-2016, 09:29 PM
  4. Why wont S4 mobile hotspot connect to pc after update?
    Last Post: 07-28-2016, 05:53 PM
  5. How to Update a Rooted HTC One M8 to Marshmallow (Currently Kit Kat)
    By Andy_Sixx in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 07-28-2016, 05:49 PM
