1. AC Question's Avatar
    So I got my Note 4 a couple weeks ago (It was used but in very good condition) and i noticed that right off the bat, the battery would last 8-9 hours from 100%.
    The Doze app don't work, clearing the cache partition don't work, Greenify is just useless IMO and when I tried, it didn't work.. in 1 hour, it would go from 100% to like 80% or a little lower just on standby!!!
    In all seriousness, i don't understand the GSAM app but it has given me a list of apps and stuff that use battery if you need that screenshot.
    I only have GSAM, Spotify, Unidays, Twitter and Snapchat on this phone so far and removed the SD card a few days ago.
    I thought 8-9 hours was normal but reading other posts on here, it's meant to last a whole day with moderate to heavy usage! (I use between moderate and heavy on some days)
    Battery is at 30 degrees celsius but goes up to 40 so the temperature is okay.
    The only solutions i haven't tried that i can think of is a hard reset, calibration or change of battery.
    Any advice is really appreciated.
    07-30-2016 12:33 PM
  2. Kroal's Avatar
    This was me who posted this btw but an example of the battery drain here is that my phone has just sat here on my desk for 10 minutes doing nothing and lost 5%. No background apps, no sync, no GPS or mobile data, the apps power usage looks regular to me although i will post screenshots on demand.
    Wi-Fi did stay on but I'm not having a phone or tablet if i have to turn the wi-fi on every time i want to use certain apps
    07-30-2016 12:50 PM
  3. belodion's Avatar
    Welcome.
    It's difficult to say what the cause is, but you seem to have done or checked the right things. I'm inclined to think a bad battery, but it's not much more than a guess. I'll pass this on to more knowledgeable members. Stand by.
    Kroal likes this.
    07-30-2016 02:04 PM
  4. dpham00's Avatar
    First thing I would try is to do a factory data reset and don't install any apps to see if you still have the same problem
    Kroal and belodion like this.
    07-30-2016 02:07 PM
  5. GRIMWALD's Avatar
    Make sure that the screen is dimmed as much as comfortable while inside, outside you will have to increase the brightness but it is what it is outside.
    GRIM
    I had to find the settings but also disable the Android device manager, on MM it is under lock screen and security, other security settings, device administrators and then turn off the the device manager.
    07-30-2016 02:24 PM
  6. Kroal's Avatar
    Okay so pray for me, I turned off the Android device manager like Grim said.. The screen brightness is on 5 and auto, and i keep my device in power-saving mode too. I put it like that when i first got it.
    A hard reset is like the second-to-last resort at this moment in time but I've got nothing to lose except for Spotify, Snapchat and Pokemon Go so that is an option.. Is this the same as a factory data reset?
    A defective battery is also a possible cause but £24.99 for a new battery is a definite last resort but if this happens, where/what is the best place to buy one?
    As an update: 52% battery and the phone says this will go in 5h 30m on power-saving mode but GSAM is saying that "Android System" has used 52.9% of battery out of 70.2%, is this normal?
    Thanks for the replies everyone!
    07-30-2016 03:12 PM
  7. B. Diddy's Avatar
    Welcome to Android Central! In these situations, it can be helpful to actually see the stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    I think you'll need to use GSam to show us the Cell Signal Strength.
    belodion likes this.
    07-30-2016 10:57 PM
  8. Kroal's Avatar
    07-31-2016 06:24 AM
  9. Kroal's Avatar
    07-31-2016 06:47 AM
  10. Kroal's Avatar
    07-31-2016 06:47 AM
  11. Kroal's Avatar
    07-31-2016 06:48 AM
  12. Kroal's Avatar
    I ran into a few problems but got the screenshots up and GSAM wasn't needed... I don't see anything unusual in the battery usage apart from the fact it is a short battery (Remember i said this is a used phone)
    07-31-2016 06:51 AM
  13. GRIMWALD's Avatar
    I seem to recall reading that Pokemon is a huge battery drain but I don't play, so I don't have any first hand knowledge of it..
    GRIM
    07-31-2016 07:55 AM
  14. Kroal's Avatar
    It is during use because you got a game, camera and GPS all being used at once.. It don't show on them charts though as a battery drain
    07-31-2016 10:41 AM
  15. B. Diddy's Avatar
    I don't see anything unusual either in those screenshots. It'd be hard for me to believe that Pokemon Go is causing the drain, since the phone is hardly ever awake. My guess is that the battery is aging and can't hold much of a charge any more. This will always happen to batteries after enough time, but can be hastened if the user frequently drains it to 0% or near-0%. I'd say get a new battery--or see if you can borrow someone else's battery for one charge cycle, to see if the battery life is significantly better.
    Kroal likes this.
    07-31-2016 05:29 PM
  16. Kroal's Avatar
    OK thank you, no shops around where I live sell I am sung note 4 batteries so would Amazon be too risky? Or would a phone repair shop help?
    07-31-2016 05:35 PM
  17. Kroal's Avatar
    There is nobody else i can borrow a battery from either as nobody I know has this phone
    07-31-2016 05:36 PM
  18. B. Diddy's Avatar
    Try a phone repair shop first and find out how much it costs. If it's much more than what you can find on Amazon, then order it from Amazon--but look for one that is sold directly through Amazon, rather than a 3rd party seller. The latter is still ok, since Amazon can help you if you have any problems with it--it just might be more of a hassle.
    07-31-2016 05:53 PM
  19. Kroal's Avatar
    Is there a chance it could still be a phone fault? Not the battery?
    07-31-2016 06:06 PM
  20. B. Diddy's Avatar
    Sure, there's always that possibility. But the battery is the more likely culprit.
    Kroal likes this.
    07-31-2016 10:15 PM
  21. Kroal's Avatar
    OK thanks! I decided I'm taking it to a phone repair place sometime so they can just make sure that the battery is the problem because £25 for a battery isn't exactly a small donation and I'll come back with the update!
    B. Diddy likes this.
    08-01-2016 04:26 AM
  22. Kroal's Avatar
    I got a new battery.. The guy said "Charge it to 100%, then restart the phone".. Did that
    10 hours 36 minutes left on 100% on new battery
    Ideas?
    08-04-2016 08:23 AM
  23. B. Diddy's Avatar
    The estimated battery life is based on prior usage, and since your prior battery may have been deteriorating, this is probably an incorrect estimate. Use the phone normally, and see how long it really lasts.
    08-04-2016 01:39 PM
  24. Kroal's Avatar
    If there's no hope, how long should I give it before I get a return on the phone ? (I installed the new battery about 8 hours ago from now)
    08-04-2016 02:23 PM
  25. belodion's Avatar
    Is the battery performing well?
    08-04-2016 02:35 PM
58 123
  1. Galaxy J1 GPS Conundrum
    Last Post: 08-01-2016, 02:49 AM
  2. Will i lose my videos if I log off of instagram?
    Last Post: 07-30-2016, 05:59 PM
  3. G900V Lollipop - can't receive phone call when BT is on
    By Steve_Karl in forum Samsung Galaxy S5
    Last Post: 07-30-2016, 02:51 PM
  4. how can I down load my photo to my new laptop
    Last Post: 07-30-2016, 02:35 PM
  5. Remove red eye on Nessus 5
    Last Post: 07-30-2016, 02:07 PM
