1. caltryst1720's Avatar
    went away and when i got home i couldn't connect to my home wi-fi . the wi-fi page is scanning all the time time and the wi-fi that i use is coming up with not in range,however all other phones and tablets are working fine from the same wi-fi address. i have a Samaung Galaxy pro tab SM-T520 model. Help is needed badly
    08-01-2016 06:53 AM
  2. the tall guy's Avatar
    Hi, have you tried turning the wifi on and off to see if that helps? also try and disconnect some devices that are on the wifi to see if that helps your device connect.
    08-03-2016 04:58 AM
  3. B. Diddy's Avatar
    Welcome to Android Central! I would also reboot the router. See here for other ideas: http://forums.androidcentral.com/amb...-problems.html
    08-03-2016 01:07 PM
  1. Why cant my phone view PDF files?
    Last Post: 08-03-2016, 04:52 AM
  2. Replies: 1
    Last Post: 08-03-2016, 04:45 AM
  3. Why is my HTC Desire 826 phone screen flickering?
    Last Post: 08-01-2016, 06:27 AM
  4. Can I make a micro sd sim and put it on a wifi only tablet?
    Last Post: 08-01-2016, 06:21 AM
