1. AC Question's Avatar
    My HTC desire 816 with virgin mobile won't connect to 4g or 3g. Mobile data hasn't worked for a week now, after my trip to mountains. I've tried soft resets and restarting but LTE eventually disconnects again no matter what. SIM card is in. Virgin Mobile customer support has no idea what's wrong; I'm in a good service area. In January I had this issue and soft reset worked after several tries.
    I lose my ip address in 4G settings when the signal dies, can't manually enter one. I can't call or text, or use GPS without restarting my phone but the signal always dies anyway after 30 minutes or so.
    08-01-2016 12:15 PM
  2. GRIMWALD's Avatar
    You should be able to just reset your network settings from the "Backup and reset" menu.
    You could also turn off the Enhanced LTE service located in the Mobile Data menu.
    GRIM
    08-01-2016 12:33 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! Have you also considered asking Virgin for a replacement SIM card?
    08-01-2016 12:51 PM
  1. Replies: 1
    Last Post: 08-03-2016, 04:33 AM
  2. Replies: 2
    Last Post: 08-01-2016, 01:04 PM
  3. When I move an app to SD Card a popup says couldn't move
    Last Post: 08-01-2016, 12:57 PM
  4. Replies: 2
    Last Post: 08-01-2016, 12:56 PM
  5. How do I get rid rid of split view screen on my tablet?
    By Eassonr in forum Ask a Question
    Last Post: 08-01-2016, 12:54 PM
