1. AC Question's Avatar
    I own an Android 5.1 Lollipop.When I Enable the location services to Check the Google Maps then It works in Battery Saving Mode.Due to Battery Saving Mode,the Location is getting determined by Wifi or Mobile Network only.The High accuracy mode option is not in the location setting.Due to which Iam unable to use the Google Maps.Can Someone help me?
    08-03-2016 12:51 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Which device do you have? Are you sure it has a GPS radio?
    08-03-2016 03:33 PM
  1. Replies: 2
    Last Post: 09-17-2016, 04:47 AM
  2. my gs7 doesn't show where to turn on hotspot
    By Adam Flake in forum Samsung Galaxy S7
    Last Post: 08-03-2016, 09:27 PM
  3. Why dont my zte obsidian wifi dont turn on
    Last Post: 08-03-2016, 03:45 PM
  4. Why is my fantasy wireless charger malfunctioning?
    Last Post: 08-03-2016, 03:40 PM
  5. can i use s7 cable in my s5 mini?
    Last Post: 08-02-2016, 09:06 PM
