1. AC Question's Avatar
    Samsung Galaxy 6 Edge. For the past several days when I receive a text there is no notification sound. I have checked, rechecked and changed sounds, but still nothing. I have rebooted and restarted many times. I have shut down and waited then turned back on. All to no avail. I have searched the web and found no help. Any ideas what I can do? Thank you.
    08-03-2016 04:16 PM
  2. Tim1954's Avatar
    Open messaging, touch more, touch notifications and you'll have a menu with the settings you need. If they are on and you are running Marshmallow, you also have a notifications setting in your main settings menu where you can turn off notifications from individual apps. Finally, in your volume settings, you have individual setting for notifications, separate from ringtones... Check all these and see what happens.. Cheers
    08-03-2016 09:07 PM
  1. Replies: 2
    Last Post: 08-17-2016, 09:01 AM
  2. Sound Comes though Speakers and Headphones
    By GeoJono in forum Moto X Pure Edition
    Last Post: 08-05-2016, 09:51 AM
  3. Text drawing
    Last Post: 08-03-2016, 04:17 PM
  4. Replies: 0
    Last Post: 08-03-2016, 03:02 PM
  5. Replies: 0
    Last Post: 08-03-2016, 02:49 PM
