1. AC Question's Avatar
    The battery on my Samsung galaxy Tab 4 drains frustratingly fast. I went to check what was using most of my battery and android os was using 135% of my battery. Don't understand how it could even use that much. Can anybody help?
    08-06-2016 04:51 PM
  2. Kelly Kearns's Avatar
    Welcome to the forums! Without root especially, it is hard to tell. That is really a "bucket" for a lot of things.
    Have you reset the tablet? Did it upgrade recently?
    08-06-2016 06:35 PM
  3. B. Diddy's Avatar
    Welcome to Android Central! It would help to see your battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal if your tablet has 4G capability).
    http://forums.androidcentral.com/amb...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph (again, if your tablet has 4G capability).
    08-06-2016 11:09 PM
  1. Cant lock my phone using Lock screen and security
    Last Post: 08-14-2016, 05:45 AM
  2. Replies: 2
    Last Post: 08-06-2016, 11:27 PM
  3. Cant connect to my mobile network
  4. Why is wifi slow and/or disconnecting on Galaxy Tab 4?
    Last Post: 08-06-2016, 11:26 PM
  5. Can I read my ibooks on my galaxy note 5
    Last Post: 08-06-2016, 11:23 PM
