1. AC Question's Avatar
    I have the new samsung galaxy wireless charging pad, it charges for about 5 seconds then turns off saying the wireless charging paused. What is my problem? This is the second one I've had that does the same thing. It charges perfect without the pad just inserting the charging wire direct.
    08-07-2016 09:57 AM
  2. Kelly Kearns's Avatar
    Welcome to the forums!
    Have you talked to Samsung Plus to see if there is a setting you need to change on your phone?
    If the app isn't on your phone, you can download it from the play store. You can video chat and even video chat and not use your video. It is more specialized than 800 Samsung and much quicker.
    08-07-2016 11:21 AM
  3. GRIMWALD's Avatar
    Try to position the device in a different spot on the pad, I think the Samsung pad only has one charging coil.
    Also if you have your device in a case, you can remove it to see if it, is the issue.
    GRIM
    08-07-2016 11:50 AM
  1. Soft keys not working and other issues after loop rebooting.
    By MadDog1977 in forum Samsung Galaxy A5
    Last Post: 08-07-2016, 10:29 PM
  2. How to recover pictures and videos on samsung grand Prime
    Last Post: 08-07-2016, 08:51 AM
  3. Replies: 0
    Last Post: 08-07-2016, 08:39 AM
  4. why mi selfie camera it's not working?
    Last Post: 08-07-2016, 07:47 AM
  5. why my LG G4 software is out of work?
    Last Post: 08-07-2016, 07:43 AM
