1. AC Question's Avatar
    Cannot get my phone to work with the hand sigh on left hand corner
    08-07-2016 02:12 PM
  2. Kelly Kearns's Avatar
    Welcome to the forums!
    Can you please register and post a screenshot of the icon you are seeing?
    Thanks!
    08-07-2016 02:15 PM
  3. Javier P's Avatar
    Welcome to the forums. What device do you have? As Kelly Kearns said, a screenshot could be very helpful. Just in case, check if TalkBack is activated in your accessibility settings. You'll need to swipe with two fingers to navigate through the menus and double (or even triple) tap to select the different options. Tell us house it goes
    08-07-2016 03:44 PM
  1. Replies: 2
    Last Post: 08-08-2016, 10:39 PM
  2. have 103 dBm 5asu. what should it be?
    Last Post: 08-07-2016, 05:12 PM
  3. Replies: 16
    Last Post: 08-07-2016, 03:36 PM
  4. My battery died wont turn on
    Last Post: 08-07-2016, 02:07 PM
  5. How do I find someone to write an Android app?
    By AC Question in forum Developers Lounge
    Last Post: 08-07-2016, 01:52 PM
