1. AC Question's Avatar
    Phone name: Aqua Power HD.
    Camera app is missing from settings. I have done the Factory Reset, other fixations through diff. apps like Camera Restarter, Camera fix (CM). None of them got success. Rebooting , etc. Nothing is helping me out. Along with this I have started getting another error i.e. "Unfortunately, Gallery has stopped." Previously, I was able to get into the camera settings from there I could set camera to the Factory Defaults. Now, all the tabs are grayed out. It just says, "Can't connect to the camera. Please make sure that to close other apps that may use camera or flashlight, Then gives OK option to click on".
    After doing all this I'm feeling like I should throw this phone on the face of Intex's founder (phone). Just to make their money they can develop any garbage which is full of ****.
    Please somebody help me that will be greatly appreciated. Hope to hear from someone soon! TIA
    08-08-2016 10:09 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which temporarily disables all 3rd party apps. On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
    If the problem disappears in Safe Mode, then something you installed is causing the problem. You may have to uninstall apps one by one until the problem disappears. If the problem persists in Safe Mode, then it's more likely to be a hardware or firmware problem.
    08-08-2016 10:47 PM
  1. Deal: Is it wise to post deals from eBay sellers
    By Habibie in forum Android & Tech Deals
    Last Post: 09-10-2016, 11:10 AM
  2. Can computer recognize phone when phone is turned off?
    Last Post: 08-08-2016, 09:32 AM
  3. Why call wating option is not selected
    Last Post: 08-08-2016, 09:25 AM
  4. Why call wating option is not selected
  5. Screen light up (wake up) is delayed or non responding.
    Last Post: 08-08-2016, 07:23 AM
