1. AC Question's Avatar
    I broke my phone a few months after getting it, brand new Galaxy s7 edge - Silver. I have been trying for about two months to figure a way to get it repaired and after visiting several repair shops I have come to this conclusion : The Silver parts are so in-demand or under-stocked that they are *much* more expensive than the black or gold parts.
    So my question is, can I get a black digitizer/lcd for my silver samsung ? would it be compatible ? They both have the same ID (att) SAMSUNGSMG935A
    08-08-2016 08:28 PM
  2. nahoku's Avatar
    I would think only the case is a different color with everything else the same. You might try calling a repair shop, or directly contacting Samsung via email to get the correct information.
    08-08-2016 10:53 PM
  1. Where is clipboard on Kyocera phone
    Last Post: 09-02-2016, 07:20 AM
  2. Constant notification noise and vibration.
    Last Post: 08-20-2016, 12:57 PM
  3. Best Bluetooth headset with Caller name announcement is a must
    By leopardgirl in forum BlackBerry Priv
    Last Post: 08-13-2016, 05:47 PM
  4. Problems with gmail and music streaming after marshmallow update
    By acorn724 in forum Samsung Galaxy Tab S2
    Last Post: 08-10-2016, 06:20 PM
  5. Replies: 5
    Last Post: 08-09-2016, 07:06 AM
