1. AC Question's Avatar
    I have tried almost all the chargers but it wont charge on sockets, car but only gets connected with PC not even laptop., can someone help me please i have tried rebooting, cleared cache but nothing seems to be solving this problem please help.
    08-09-2016 11:40 AM
  2. belodion's Avatar
    I'm not quite sure what you're saying will or will not work, but perhaps the USB port is damaged?
    08-09-2016 12:03 PM
  3. partying19's Avatar
    Hi, my s6 edge won't charge on wall sockets. I mean it only charges when its connected to computer. I have tried changing the chargers, cables but it does not charge. I have tried rebooting, cleared the cache, factory reset but did not help. I think its a software glitch because this happened after many updates of app's before that it was working perfectly fine. can someone please help?
    08-09-2016 12:23 PM
  4. partying19's Avatar
    I do not believe so that is because it is charging fine when its connected with computer. see the below post if that helps you to understand the problem.
    08-09-2016 12:25 PM
  5. belodion's Avatar
    Welcome as a new member
    I wonder whether, somehow, USB Debugging has got switched on in Developer Options?
    08-09-2016 01:30 PM
  1. AT&T Note Edge - Giving up on this device
    By Talderon in forum Samsung Galaxy Note Edge
    Last Post: 08-10-2016, 03:32 PM
  2. Case compatible with Wireless Charging?
    Last Post: 08-09-2016, 11:41 AM
  3. battery won't charge when on but charges when unit is off.
    Last Post: 08-09-2016, 11:34 AM
  4. Do you need internet to read books on an ereader?
    Last Post: 08-09-2016, 10:49 AM
