1. AC Question's Avatar
    For the last month or so, I find my battery isn't lasting a day. Haven't changed my use any, no new apps.
    08-10-2016 04:36 PM
  2. belodion's Avatar
    Do your battery usage stats offer any clues?
    Is your signal the same strength as before?
    By all means post a screenshot of your battery usage stats after a day's use, before you need to recharge.
    The answer to your title question is 'Yes, I have', and I suspect that the two of us are not alone.
    08-10-2016 06:53 PM
  1. Replies: 12
    Last Post: 12-06-2016, 01:05 PM
  2. What to do if my Kyocera phone says device needs attention? I
    Last Post: 08-26-2016, 12:19 PM
  3. Will it be possible to import the 6gb ram China note 7 to the U.S ?
    By johnnycaputo34 in forum Samsung Galaxy Note 7
    Last Post: 08-10-2016, 05:57 PM
  4. Replies: 0
    Last Post: 08-10-2016, 04:12 PM
  5. Replies: 0
    Last Post: 08-10-2016, 04:01 PM
