1. AC Question's Avatar
    I am using Note 4 over 2..3 months.. since a few days I have been facing a problem with the speakers..after listening to the music for about 20-30 minutes the speakers start with a cracking sound..and screen goes off
    08-12-2016 08:07 AM
  2. Chris Parsons's Avatar
    You could try doing a factory reset to see if that fixes the problem, though it does sound as though it may be more of a hardware issue. A factory reset would help determine that too though due to the fact that if it persists after, then you know it's hard related.
    08-12-2016 01:52 PM
  1. Sync Personal Outlook Calendar with my Note 4.
    Last Post: 08-19-2016, 02:59 AM
  2. Replies: 2
    Last Post: 08-19-2016, 02:58 AM
  3. Replies: 1
    Last Post: 08-19-2016, 02:57 AM
  4. Android 7.0 Nougat to hit the Galaxy Note7 in "two to three months"
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 7
    Last Post: 08-13-2016, 12:33 PM
  5. Screeching and popping noises during calls
    Last Post: 08-12-2016, 08:28 AM
