1. AC Question's Avatar
    hello all my N9 started behaving very very strange to the point that i cant use it . it started with random shutdowns later on it just stoped turning on . when i did manage to turn it on there would have been yellow spots all over the screen until it would turn up then shutdown right away. i tried making factory reset that worked !. but the problems stayed. because i purchased it in the US but i live in Israel i cant really use any warranty that i might have had so i gave it to a shop in my city to try to fix it . the shop seller said he cannot do nothing that he checked its not the battery or the screen itself and it might be a version problem or the HD itself. he said all so he tried burning a new image on the device but was not able because already did a factory reset ( some check box is not turn on anymore and he cannot change it ) have you ever heard about such problems is there is thing i can do \ try to make it work again ?
    08-13-2016 04:16 AM
  2. the tall guy's Avatar
    Hi, you could have sent it back to the original seller and asked for your money back / replacement - but since you've taken it to a local shop and they've opened the device up, I don't think there is anything you can do. Is there another local shop near by for a second opinion?
    08-19-2016 07:40 AM
  1. android 4.2.2 auto enabling wifi problem
    Last Post: 08-19-2016, 07:36 AM
  2. Portable charger for Nexus 6P
    By longtime44 in forum Nexus 6P Accessories
    Last Post: 08-14-2016, 02:24 AM
  3. Problems after update (Samsung Galaxy s5)
    Last Post: 08-13-2016, 10:29 AM
  4. Replies: 0
    Last Post: 08-12-2016, 10:45 PM
  5. Managing Nexus 7 with chromebook
    By Snowman7877 in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 08-12-2016, 10:39 PM
