1. AC Question's Avatar
    I've owned two Galaxy Tab S2 9.7's and both had battery failure just after the warranty expired. I am about to give up on Samsungs altogether. Is the a Samsung tab that has a proven higher quality battery and power system?
    08-13-2016 12:35 PM
  2. the tall guy's Avatar
    Hi, I've owned quite a few Samsung products over the last 5 years - although battery life does depreciate, it don't get to the stage where I can't use the device.
    How bad was the battery life on the tablet? were you a heavy user?
    08-19-2016 08:05 AM
  1. Best cleaning app
    By jaleelhamid in forum Ask a Question
    Last Post: 08-14-2016, 11:16 AM
  2. Tablet not working with smart lock
    By skatergirl in forum Samsung Galaxy Tab S2
    Last Post: 08-13-2016, 02:55 PM
  3. Replies: 0
    Last Post: 08-13-2016, 12:32 PM
  4. Replies: 0
    Last Post: 08-13-2016, 12:30 PM
  5. My ok Google is not working anymore on my S7??
    Last Post: 08-13-2016, 12:12 PM
