1. AC Question's Avatar
    Spigen Neo Hybrid Bumper Case
    08-14-2016 02:26 AM
  2. Misfit Profit's Avatar
    Inductive charging uses an electromagnetic field to transfer energy between two objects. This is usually done with a charging station. Energy is sent through an inductive coupling to an electrical device, which can then use that energy to charge batteries or run the device. The further your device(Or the induction receiver behind you're glassback) is from the emitter, the weaker the signal that it recieves.
    Furthermore the the material that is used (For the most part) isn't going to affect your charge other than the added distance.
    belodion likes this.
    08-14-2016 06:07 AM
  1. Replies: 2
    Last Post: 09-04-2016, 02:58 PM
  2. Failed to back up My profile section saved in Contacts
    By Fermenter in forum Samsung Galaxy S6
    Last Post: 08-23-2016, 02:12 AM
  3. Replies: 1
    Last Post: 08-19-2016, 09:29 AM
  4. My Phone Won't Read Sim Card(?)
    By iamnotpartveela in forum Ask a Question
    Last Post: 08-16-2016, 07:50 AM
  5. Viber and WhatsApp messing my Contacts
    By gmaister22 in forum General Help and How To
    Last Post: 08-14-2016, 01:46 AM
