Nexus 5X - Why charging still drains battery?
A
AC Question
I bought a USB cable for it (USB to USB type C), and I charge it via a charger that's at the office (which works fine with older devices) .
For some reason, even while it charges, it drains battery, so much that by the end of the day, it can get to 0%.
Looking at the Ampere value (using an app "Ampere") , it seems very low (around 300mA) .
I even tried to use a Samsung charger (which was used for SGS4) . About the same Ampere value.
How could it be?
19escape20
