Galaxy S3.
This mobile gets very little use. I keep it with me turned on all day and it gets charged from about 8 pm to 4 am. Generally when I plug it in to charge it still has 75-90% charge left.
The other day at around 4 pm I noticed the charge had dropped down to 2%.
I had not used the mobile all day.
I turned it off.
Put it on the charger in the car, in a closed console and took it out at 8:30.
It showed the green battery with 100%
It would not turn on.
I tried removing the battery, the SIM card. Nothing.
Next day, from information on a YouTube video, I:
Plugged it into a power source, held the Volume Up Button, Power Button and Home (?) Button for 15 second. The blue light in the corner came on, and I clicked on the “Reboot”
It worked.
However, now every time it is plugged in there is message at the bottom of the screen “Abnormal Battery Condition.”
It appears to be holding the charge as much as it did before.
Do I need a new battery? Obviously this mobile is four or so years old.
Also, I don’t want to turn it off because I’m concerned it will not start, and I don’t know if I will be so lucky next time.
I really do not want to purchase a new one if I don’t have to—as I said, I rarely use it.
Thanks very much.
Athena
I turned it off.
It worked.
Thanks very much.
Athena
