1. AC Question's Avatar
    Please help - got home from UK where I used a local SIM card and it worked flawlessly.
    Then I came home, swapped the EE SIM to Verizon SIM then I have NO upload speed to speak off.
    I have gotten a new SIM card from Verizon and I still don't get any upload - I'd get 0.01Mb or 0 -
    Factory reset worked for a few minutes and then I'd be back to square one.
    The very same SIM card works fine with another Motorola X at the same location.
    Can anyone chime in to help -
    Thank you.
    08-18-2016 06:09 PM
  1. LG G2 Screen looks like the old TV screen after hours
    By kls4112 in forum Verizon LG G2
    Last Post: 08-19-2016, 03:08 AM
  2. Como hacer un reset factory a mi s3 mini.
    Last Post: 08-18-2016, 06:49 PM
  3. my LG android phone is saying no command
    Last Post: 08-18-2016, 05:42 PM
  4. Replies: 0
    Last Post: 08-18-2016, 02:38 PM
  5. Will my Wi-Fi still try to connect after I shutdown my phone?
    Last Post: 08-18-2016, 02:28 PM
